Create any seamless Anatomical Element Textures for any Gen9
I found this tutorial on Renderhub, but I need help. Is there anyone who uses this trick? - Create Any Seamless Genital Textures for Any Gen9
What should I do in the first step "Load your Gen 9 and the Complete texture set you want to use on it."?
I'm new to DAZ, I did everything as your tutorial says, but nothing happened, genitals area was still grey. I have my DAZ female body loaded into scene, I applied default DAZ female genitals mesh. Then I applied skin (as metrial), skin on the whole body changed except for genitals area, it's still grey, textureless.
What should I do next? Is there any difference between skin (material) and complete texture set mentioned in the tutorial?
If it matters the skin I'm using is Addy Rylee Genesis 9 skin and DAZ figure is of course Genesis 9
I haven't tried that method.
I made an alternative UV map for genesis 9 female some years ago https://www.daz3d.com/forums/discussion/598936/alternativ-uv-map-for-g9-female-anatomical-elements/p1
The site is giving gateway errors, but I have provisionally removed the link as it seems likely to have images that break the ToS.
