Is there a way to add a column to the Content DB Editor ?
ElorElor Posts: 3,623
Hello,
The Content DB Editor has a lot of columns (File Name, File Ext, File Type, Type, Audience, etc), a couple who are rarely if ever useful while creating metadata, but it's missing a column to easily check if every file has its category set:
Is there a way to add it ?
Post edited by Elor on
  • Richard HaseltineRichard Haseltine Posts: 109,533
    You could write your own, but you can't configure this one as far as I know.
    We are told you should keep an eye on the DS 2025 change log (not DS 4 as new work is now going into 2025).
  • ElorElor Posts: 3,623
    Thank you for both answers :) I'll keep an eye on the change log then :D
