Hip distorsion
golem841golem841 Posts: 188
Hoping it's not against the TOS.
I have this weird distortion at the pelvis-legs joint, even in less extreme position
I tried to find a hidden morph to no avail. I have installed Gen Shift + Gen Gap for Genesis 9 , Ultimate Natural Bend Morphs for Genesis 9 Feminine 2.0 and Ultimate Natural Bend Morphs for Genesis 9 Female Base
Anybobody have an idea of whats causing this ?
  • Richard HaseltineRichard Haseltine Posts: 109,314
    It certainly looks like a JCM or the like triggering when it isn't needed, although it could also be one not triggering when it is. Make sure you are not missing any updates for those products.
  • golem841golem841 Posts: 188
    Thanks Richard,
    Is this JCM problem is visible in the log file ?
    It probably isn't an error in the sense of something failing, it's likely something in one or more products not set as it needs to be - that isn't an issue DS can detect, it has no idea how things are meant to work and just follows the set up it is given. It may still be worth a check, in case there is a real failure that is causing the issue you are seeing, but I wouldn't bet on that being productive.
    I'm stuck.
    I will finish with a total delete of everything G9 character related.
    It's a pity that the Daz3d folders are such a mess, every creator has a "personnal" sub folder.
