[Released] Lantios Backdrops Bundle
LantiosLantios Posts: 117
edited June 2025 in Daz PA Commercial Products
With this bundle I'm going back to my roots at DAZ and focusing on character lighting and combined that with my prop making to create some snazzy backdrops that you can fully customize, colorize and mix and match to create different vibes. I wanted to focus on "magazine cover" and "fancy photoshoot" vibes and I think this bundle achieves that. I'm really happy to present the Lantios Backdrops Bundle, which will be coming soon!
The Retrop Pop Backdrops focused on a Memphis Design inspired prop and texture set; using layered shaders, you can stack up to 3 patterns on top of each other and change materials and colors to achieve some very fun and maximalist looks.
The Curtains & Portals Backdrops have a bit of dramatic flair and a more classic vibe, using doors and windows as our portals to create visual interest and frame the subject, as well as creating different lighting opportunities. The different fabrics on the curtains allow you to set the mood, from romantic lace, to cozy velvet, to a warm fabric and an embroidered fabric for added flair.
The Contemporary Backdrops switch things up and can give runway or museum vibes; the bench serves as a focal point, but so do the slatted walls. The tiles can be mixed and matched to create floors, walls, or interesting art pieces and the set is meant to look very modern and fashion.
And of course, to tie them all together, is the Softbox Lighting Kit, which contains a morphable softbox prop and an array of colored emissive presets as well as color temperature and intensity presets so you can very quickly change your lights without too much effort. Also included are some premade three-point lighting presets that can get you started, but the beauty of the softbox prop is that between the presets and the included morphs to change its shape (which affects light spread and intensity) you can really customize your lighting to the fullest extent.
I hope this bundle serves you guys well. It was a blast getting to play around with lights again in a more focused way and also to make a bundle that focuses on character shots vs the environment work I've been doing since starting up again as a PA!
Retro Pop Backdrops
Post edited by Lantios on
