[solved] Figures disappeared from Smart Content
CherubitCherubit Posts: 995
edited October 2015 in New Users
I need help :'( I had to install again my DS because I was having a problem, and now none of my Genesis will show up in smart content panel, not to tell other items... I installed everything again and nothing.... Can anybody help me please? Below, a print screen of how the Figures (it's the only one that I noticed missing so far, but I had a huge list there...) folder doesn't show up...
(Yes, they show up in content library if I go manually, but not in my smart content)
Post edited by Cherubit on
  • CherubitCherubit Posts: 995
    Problem solved, I got help in facebook from John Hinton: " If they show up under Content Library, but just not under Smart Content, the database may be corrupted. To fix that, right click on the 'Content Libary' tab and choose 'Content DB Maintenance'. Then check 'Re-Import Metadata' and click Accept. Depending on how much content you have and how fast your computer is, this could take from a few minutes to an hour or more. Before doing that, be sure the content is showing in Content Library. If it isn't, you need to right click Content Library and go to Content Directory manager and create a path to your Daz content."
