I need rigged cables, wires, that can be attached to a genesis character (CYBERPUNK)
Aaron-HCGAaron-HCG Posts: 40
edited May 2025 in The Commons
Hi I keep seeing those wiring attached promotionals cyberpunk render in the daz store, working for genesis character but I don't know if they are photoshopped or its an actual product for daz.
Can't find anything close in the store. They dont need to be rigged but easy to setup thanks!
Post edited by Aaron-HCG on
  • dtrscbrutaldtrscbrutal Posts: 569
    You might take a look at Flex Pipes.
    If you are inclined towards post work, look at Ron's Cables & Hoses.
  • namffuaknamffuak Posts: 4,447
    edited May 2025
    Post edited by namffuak on
  • markusmaternmarkusmatern Posts: 604
    Had really good results with "CES 3D’s Tube Maker for Daz Studio". It's a script from 3dshards.com. They are not rigged, but can be generated on demand via control objects.
    Those are not photoshopped.  Daveyabbo created his own custom models most likely using Zbrush.  Otherwise you are left with Marketplace items such as the others have mentioned.
    At Renderosity's shop from Powerage is a product called "Electro Kit" with eight (or so) different cables and some other things to give your cyborg starting help wink
