Blue Star Wireframe appearing on the model how to get rid of it?
aadarsh.satputeaadarsh.satpute Posts: 69
edited May 2025 in The Commons
[Blue Star Wireframe appearing on the model how to get rid of it?] This is what is appearing on model and one car i am using how to get rid of it. I tried hiding and unhiding everything cant understand what causing this. See the attachment below. Thank you for help.
  • felisfelis Posts: 6,166
    My first thought was that it might be a reflection, but after looking closer I don't think it is.
    What happens if you rotate the camera a few degrees?
  • FirstBastionFirstBastion Posts: 8,056
    Can you switch to hidden line view in the dazstudio window and take a screen shot of the meshes?
    Still the same how ever I rotate
    I dont see anything unusual.
    1285 x 1223 - 350K
    1290 x 1228 - 149K
    1283 x 1224 - 413K
  • Richard HaseltineRichard Haseltine Posts: 109,577
    What happens if you let it render for longer? How is the scene lit?
  • Yeah Still you can see it after full render. The sceen is lit by the celing of the room nothing else.
  • Just figured out it is HS dforce Hip and Breast Addon causing the issue. Maybe I need to figure how this thing works properly.  Thank you guys for help/
  • ElorElor Posts: 3,638
    Check that the dForce addon related to each element is not visible to render.
