Adding to Cart…
It impacts the card displaying the image, which may or may not be a card involved inthe render. It has a lesser impact on the cards doing the render, if they are different. In both cases the impact is relatively small, unless you go to extremes.
We had a tester using an external case for Video cards, and a ground cord got, accidentally, cut. Burned up three cards.
But they need it from PSU's that provide well over those levels as failure to provide these cards with the consumption requirements they require could damage them or the rest of your system permanently. Power consumption from the last few generation of Nvidia cards has changed little but power requirements are still remain well above that threshold as the manufacturer states.
For a Titan X Nvidia suggests the minimum size of the PSU in your desktop should be powered by no less than a 600 Watt PSU
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-titan/specifications
and the 960 is at the very least requires a 400 Watt PSU
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-960/specifications
If you stick a card that maxes out at 120Watts of power in a case with a 350W PSU because you supplement wattage consumption with power requirement you could turn your rendering box into a smoldering brick doorstop.
I just popped in a GTX980 with 2 1/2 yr old 32G system and using 890M on ROG 24G laptop big scene multiple figures no problem dont even need to hide or delete any from scene to scene. I am getting some strange color bug on the 980 I tried some stuff suggested on the net to no avail. (Resolved with nvidia support)
