HDMI Scenes.
Recently purchased some scene items. It says DUF under the content photo. But I have found you have to load the image in HDMI  mode to see the image other than rendering it. In render it is there. Butin render you can not add to the image. How do you set Daz to show the actual HDMI file so you can place other items in the scene.
  • MattymanxMattymanx Posts: 7,000
    You cant.
    What you can do is set your render mode to interactive and use the Iray viewport to see the HDMI while adding items to the scene.
    Just remember to set the render mode back to Photoreal before doing the final render
  • Richard HaseltineRichard Haseltine Posts: 109,470
    What do you mean by HDMI? That is a connection standard, as far as I know. Is this an issue with instances not showing, or accurate material previews?
