Happy as a Clam Hierarchical Poses for G8.1F, Fulcia Mertail, and Under the Sea Props
Rendo link: https://www.renderosity.com/freestuff/items/98720/happy-as-a-clam-poses-for-g81f-fulcia-mertail-and-under-the-sea-props
Renderhub link: https://www.renderhub.com/modernwizard/happy-as-a-clam-poses-for-g8-1f-fulcia-mertail-and-under-t
Happy as a Clam Poses for G8.1F, Fulcia Mertail, and Under the Sea Props
Daz Studio only
Tested only in Daz Studio Pro 4.23 64 bit.
DESCRIPTION
This is a set of hierarchical poses for Genesis 8.1 Female and Fulcia Mertail for Genesis 8.1 Female [tail and hip fins but NOT the weird back rods] by Arki. The poses are made so that the figure can interact with the clam and pearl from Under the Sea Props for Genesis 8.1 by ThreeDigital. Have your merperson discover, carry off, and clown around with some ocean treasure!
To use these poses, prepare G8.1F by loading the Fulcia tail. Select G8.1F and apply a hierarchical pose preset to pose both G8.1F and tail. Load the corresponding Under the Sea props and apply the poses to them. Some poses require the Under the Sea clam with parented pearl, and some just require the pearl unparented. File names indicate which props you should use.
Turn limits off G8.1F and Fulcia Mertail for best results.
PACKAGE INCLUDES
25 hierarchical poses for G8.1F and the Fulcia tail: 12 poses, 12 mirrored poses, and 1 pose to restore G8.1F and the Fulcia tail.
3 poses for the Under the Sea clam and parented pearl: 1 pose, 1 mirrored pose, and 1 restore pose.
3 poses for the Under the Sea clam: 1 pose, 1 mirrored pose, and 1 restore pose.
12 poses for the Under the Sea unparented pearl: 5 poses, 5 mirrored poses, 1 restore pose, and 1 pose to put the pearl in its default position in the clam.
Please note that the poses include some silly and suggestive ones with the pearl positioned in the crotch area.
PACKAGE REQUIRES
Genesis 8.1 Female figure
Fulcia Mertail for Genesis 8.1 Female by Arki: https://www.daz3d.com/fulcia-mertail-for-genesis-81-female
Under the Sea Props for Genesis 8.1 by Three Digital: https://www.daz3d.com/under-the-sea-props-for-genesis-81
LOCATION
After installation, find the poses under under Content > People > Genesis 8.1 Female > Poses > ModernWizard > Happy as a Clam > Clam and Pearl Poses
and Content > People > Genesis 8.1 Female > Poses > ModernWizard > Happy as a Clam > G8.1F and Fulcia Poses.
USAGE NOTES
Use however you want.  Just don't repackage and call your own. Have fun! No attribution required, though I always like to know where people have used my work.
ABOUT ME
http://oddpla.net/modernwizard/
If you do use any of my freebies in your work, feel free to drop me a line [ModernWizard at the Daz boards, ModernWiz on Renderosity]. Thank you.
  • Faeryl WomynFaeryl Womyn Posts: 3,777
    Love the pose packages. Wondering if this the tail would fit G8 or is it only 8.1 ???
  • ModernWizardModernWizard Posts: 904
    I would imagine that it would work for G8F if you changed the figure ID [either of the G8F or the tail -- not sure which, haven't tried this process].
    --MW
  • LeanaLeana Posts: 13,504
    edited May 2025
    The tail fits G8F, but there's a geoshell to blend the tail and skin and the materials for the torso part of the geoshell don't get applied as the torso surface doesn't exist for G8F.
    I think you could copy them over though (load the shell on a G8.1F, copy settings for the torso surface of the G8.1F shell and paste them to the "body" surface of the G8F shell)
    I've not checked the materials folder but if there are hierarchical materials they likely won't work when used on G8F.
    Post edited by Leana on
