Best way to fix dforce hair that has parts that don't simulate?
I'm working on a render where my character has their head leaning back, and I'm using https://www.daz3d.com/eirgrid-hair-for-genesis-9. When I simulate the hair, most of it works, but the braids don't seem to have dforce applied. They just stay static. Am I missing something? How could I fix this most easily? The back braid in particular is jarring because when I pose it to get it to hang down, it just kinks in one spot like below. That's from posing, not dforce. Dforce doesn't change it at all.
I don't have a lot of experience adjusting weight maps or that sort of thing, but I am great at following directions or tutorials when I know the direction I should be going. :) (Same goes for rigging if adding bones would be the best option. Zero experience there, but if I know the terms to search for for a tutorial, I'm sure I can figure it out.)
Thanks!
  • felisfelis Posts: 6,168
    There are bones in the hair. Try to expand, and see if dialing those can help you.
  • ShadowdreamShadowdream Posts: 118
    edited May 2025
    Am I missing something? Because I don't see multiple bones in the braid and I can't expand it further. (screenshot attached) It bends in one place.
    295 x 511 - 17K
    Post edited by Shadowdream on
    There is only one bone per braid, so you can bend it, but can't make it curve or curl.
    It is a little limited. So if you find it in suffucient, you can add extra bones yourself.
