help with lighting plz.
dondrawdondraw Posts: 170
i have this scene with this model, and my help tab doesn't bring up the references so i'm flying blind. for the render i need brighter light on her, but i've tried a lot of stuff and nothing so far works. i know it's daz and should be not omplex to achieve this, but i've added different lights and increased intensity (lumens don't change, tho) and still, no change in viewport or render. what please may i do to achieve better ccontrol?
  • Richard HaseltineRichard Haseltine Posts: 109,626
    Increase the Luminosity, not the Intensity for iray. You could also use the Tone mapper settings (on the scene node, or in Render Settings, to increase  the exposure without changing the lights themselves.
  • ChezjuanChezjuan Posts: 544
    Also, check your render settings and eake sure that your environment for the render are set to "Dome and Scene." If it is set to "Sun/Sky Only" then spotlights, pointlights, etc. will not do anything.
