Daz says textures don't exist..
Hello, I'm trying to apply a full body wardrobe to my genesis texture (Guardian Bodysuit) .. and I get an error that "the files listed below could not be found" /data/Mada/SuperSuitsG3F/Superhero Suit/SuperheroFemaleSuit_11761.dsf.."
I've uninstalled and re-installed the items, same results.. any idea how to fix that?
thanks
  • Richard HaseltineRichard Haseltine Posts: 109,603
    edited May 2025
    Moved to Technical Help as it is nota Daz Studio application topic.
    It isn't textures, it's the basic model. I suspect the set you have is a texture set for https://www.daz3d.com/super-bodysuit-for-genesis-3-female-s rather than a standalone product - in which case if it is something from the Daz store that should be listed as a required producct..
  • Ah!!! thanks for the info.. the texture set I have (wardrobe) is for Guardian Suit ... Genesis 3Female.. Let me try that I believe I tried with 8 and 9.. thinking it would adapt..
    thanks for the tip!
    Right on.. after going back to the store and looking up the assets, I saw another product was needed.. thanks again!
