Shader Mixer Displacement Strength
Hello, anyone know how I can change the value of the Displacement Strength in the shader mixer? Basically I want to animate the strength of the displacement with frames, but I can't find what to connect on this node despite it being a float value. Thanks.
  • Richard HaseltineRichard Haseltine Posts: 109,577
    Doesn't clicking None give you a browser? In any event, you could do it with the input value - but as I recall there was an issue, or at least an inconsistency with hand-written shaders, in 3De;light if not Iry where the Strength pulled the displacement value down to black as it was lowered, that is the minimum value rather than 0, so lowering the strength just swung the effect to the negative displacement; it was necessary to do some fiddling to get a value that actually lessened the displacemnt effect, as most hand-coded shaders did. This may not be true with the Iray bricks, but I would check it.
