Bandana for Genesis 9
Hi! I'm trying to make a new version of "Rosie The Riveter" ... Do you guys know any way to get this short hair with a bandana for hair?
  • GordigGordig Posts: 10,608
    This already exists if you're open to fitting a G8 hair.
  • D. ArnaezD. Arnaez Posts: 60
    Yes I seen that but I was just expecting to find a version for G9. At least to find the way or tutorial to convert it to G9 after to buy it.
  • TimbalesTimbales Posts: 2,423
    You can load it into the scene without auto-fitting it to G9. If it has a cap, I'd make the everything but that invisible, then adjust its position to where it's aligned with G9's head. Then you can use the hair's adjustment morphs or scale options as needed. Finally, manually parent the hair to G9's head and make all the surfaces visible again. Tweak if needed.
  • ElorElor Posts: 3,261
    edited April 2025
    Maybe the one from these freebies, but they don't have hair adjusted to them included, so you have to do it yourself:
    https://www.renderosity.com/freestuff/items/98661/cafe-waitress-for-g9
    https://www.renderosity.com/freestuff/items/98626/hair-ribbons-for-g9
    Then you either adjust the hairs to the ribbon(with a d-former with a weight map or with Hat Check) or play with the scaling of the ribbon to reduce clipping.
    Post edited by Elor on
  • nonesuch00nonesuch00 Posts: 18,753
    I would like to see a bandana like was popular in the 70s and early 80s among a lot of older teenage males and still popular among male motorcycle riders. It's the stereotypical wearing style old tyme pirates wearing bandana wore.
