Cache issues.
Hi I've been using DAZ for a little while now, and my C drive has completely filled up.
I now get a warning of a shortage of space and possible errors.
The rendering process obvioously requires space and creates a cache somewhere for this purpose. How can I clear this cache or directive DAZ to use an alternate HDD for this purpose.
Thanks
Kiaran
If you go to Edit > Preferencees, in the General tab, you will see two paths for Temp files and DSON Cache files, you could try changing them.
One other gotcha. Do you use DIM to install your content? If so, its default behaviour is to store the downloaded content installers as well as the content files extracted from the installers and copied to your content library. If you don't realise what's happening, your C: drive space can shrink away to nothing in an amazingly short time.
