Daz Studio 2025 (6.25.2025.x) - NVIDIA Iray 2024/2025
rbtwhiz
When a new build of Daz Studio includes a new version of the NVIDIA Iray renderer, the new build of the renderer comes with its own set of bug fixes, new features, adjustments to existing features, etc. Since the release of Daz Studio that followed the initial introduction of NVIDIA Iray in Daz Studio (4.8 - initial introduction, 4.9 - following release), a list of its changes have typically been made available in the posts that immediately follow the announcement. In many cases, while the information contained within the posts was/is useful to those that want/need it, it seemed to go unread by many. This same information would also then be reposted when a Public Build was eventually promoted to General Release.
To address some of these issues and bring more visibility to the changes for those who want/need it, we now split these posts off into their own thread. A separate discussion thread will remain available (linked below), but the thread itself will be closed for comment so as to avoid the information being buried by the discussion and to provide notification through regular features of the forum software.
*Note: The entries below come directly from the NVIDIA Iray release notes. Some entries, such as the mention of Linux, Python, etc, currently have no bearing on Daz Studio itself but are included for completeness.
Public Build Threads:
- 6.25.2025.35308 (December 19, 2025)
- 6.25.2025.32308 (November 20, 2025)
- 6.25.2025.30407 (October 31, 2025)
- 6.25.2025.27507 (October 2, 2025)
- 6.25.2025.26119 (September 19, 2025)
- 6.25.2025.25616 (September 16, 2025)
- 6.25.2025.23807 (August 26, 2025)
- 6.25.2025.22607 (August 14, 2025)
- 6.25.2025.21707 (August 5, 2025)
- 6.25.2025.21308 (August 1, 2025)
- 6.25.2025.19807 (July 17, 2025)
- 6.25.2025.17807 (June 27, 2025)
- 6.25.2025.16407 (June 13, 2025)
- 6.25.2025.14115 (May 22, 2025)
- 6.25.2025.13207 (May 12, 2025)
- 6.25.2025.12207 (May 2, 2025)
- 6.25.2025.11417 (April 25, 2025)
- 6.25.2025.11206 (April 22, 2025)
General Release Thread:
- Pending
Previous Thread:
Iray 2024.0.0 beta, build 377400.955
Known Issues and Restrictions
Added and Changed Features
- Improved displacement tessellation: In addition to the fixed subdivision schemes previously available, there is now a (configurable) "adaptive" parameter option, too. This will lead to overall less memory usage at similar quality, or much higher quality at similar memory usage. Both schemes will also employ available CUDA GPUs for acceleration. For details, please refer to the new section in the Iray Programmer’s Manual.
- Added an additional pre-tessellation step to improve low-polygon geometry objects, but that feature meaningful shading/vertex normals, via the approx_geometry_from_ shading_normals attribute. This can be interpreted as an extended replacement of the shadow_terminator_offset_mode flag, which actually works on the geometry itself, instead of just approximating the nonexistent detailed geometry. This comes at the price of increased pre-processing time, and vastly more memory usage.
Iray PhotorealFixed Bugs
Iray 2024.0.0, build 377400.1437
"Background rendering" refers to Iray Photoreal performing work outside of the scope of the IRender_context::render() function. This was introduced in 2012 to improve overall rendering efficiency.
Iray 2024.0.0 extends the situations in which background rendering is active somewhat, to further improve efficiency. Because internal jobs require an active transaction to execute, closing the rendering transaction on the application side will cancel background rendering. Most importantly, note that this is similar to calling IRender_context::cancel_render() with mode CANCEL_AND_CONTINUE. Applications which are experiencing slow/sluggish interaction should ensure that IRender_context::cancel_render is called with mode CANCEL_AND_RESTART when making changes, and before closing the rendering transaction.
In general, applications cannot assume that Iray Photoreal rendering is idle unless the render function has returned with a non-zero value.
Fixed Bugs
Iray 2024.0.1, build 377400.2109
Fixed Bugs
Iray 2024.0.2, build 377400.2626
Fixed Bugs
Iray 2024.0.3 internal, build 377400.3383
Fixed Bugs
- Fixed various issues with the improved scheduler (nvbugs 4765932 and a spurious deadlock in OV).
- Fixed a potential crash with volume scenes and caustic sampler enabled.
- Fixed some corner case math on Linux CPU rendering.
- Fixed sampling issues with extreme anisotropic volume scattering values.
- Fixed handling of empty fiber and particle objects on non-RTX (pre-Turing) GPUs (nvbugs 4852406).
- Fixed artifacts on the CPU with zero-length Catmull-Rom and Bezier fibers (nvbugs 4852577).
- Fixed handling of extreme input values for ground fog (nvbugs 4186133).
Iray InteractiveIray 2024.0.4, build 377400.3959
Fixed Bugs
Iray 2024.1.0 beta, build 381500.1577
Fixed Bugs
Iray 2024.1.0 , build 381500.2959
Fixed Bugs
Iray 2024.1.1 , build 381500.4681
Fixed Bugs
Daz Studio 6.25.2025.11206 - *Public Build*
Iray 2024.1.2 internal, build 381500.4681.754
Iray 2024.1.3, build 381500.5658
Fixed Bugs
Daz Studio 6.25.2025.16407 - *Public Build*
Iray 2024.1.4, build 381500.6583
Fixed Bugs
Daz Studio 6.25.2025.19807 - *Public Build*
Iray 2024.1.5, build 381500.6978
Fixed Bugs
Daz Studio 6.25.2025.21308 - *Public Build*
Iray 2024.1.6, build 381500.7597
Fixed Bugs
Daz Studio 6.25.2025.27507 - *Public Build*
Iray 2025.0.0 beta, build 387700.770
Fixed Bugs
Iray 2025.0.0, build 387700.1252
Fixed Bugs
Iray 2025.0.1, build 387700.1606
Daz Studio 6.25.2025.30407 - *Public Build*
Iray 2025.0.2, build 387700.2211
Fixed Bugs
Iray 2025.0.3, build 387700.2665
Fixed Bugs
Daz Studio 6.25.2025.35308 - *Public Build*
