interface help, needed
am running Daz3d version 4.22.0.16, some how the viewport got changed - no more grid lines, etc..,
When i try to change it back to 'city lmits lite' it crashs and burns.
how do i change back to it's 'normal' state ?
  • namffuaknamffuak Posts: 4,409
    Viewport hamburger menu (upper right corner) click on "show floor".
  • artxtapartxtap Posts: 174
    thanks, but the show floor was/is checked - in the 1st screen shot you can see two line, if 'show floor' is unchecked those lines go away.
    Apologies - it looks like you've scrolled to an extreme closeup of the floor - I can get the same view by just using the perspective view and scrolling. Try scrolling out, or pick something in the scene and frame it.
    Nope i knew that was not it but to prove the point see screen shot.
    This kind of thing happen when you get a bad asset – the person saved things with the assent that should not have been saved, setting etc,..
    assets that were done for poser are a great example.
    I can’t get daz3d back to ‘normal’ …..‘city limits lite’ right now because doing it’s the correct way makes daz3d crash and burn.
    1360 x 693 - 169K
    734 x 368 - 63K
    Maybe this will help. The page it comes from is 404:
    Yes you can change the size of the grid - Edit, Preference Editor, User Interface, Grid. Then change the Grid Size.
    thanks for the try but Edit, Preference Editor, User Interface, Grid. is no longer there, that might be why it's in on a 404 page.
    'k, sorry. I don't have D/S on this laptop so couldn't check it. Seems logical to me that there should be something somewhere to adjust the grid size.
