Daz plugin development
Alex@DBGAlex@DBG Posts: 61
Hey everyone,
I had an idea for a plugin that would help me in my workflow, and I have tried to develop it myself. Now, I'm not a programmer, I can read some Python and C++ code, but in this I tried to use AI ( Chat GPT and Claude ).
Anyway, We got some code working, but I got stuck at the QT part of it.
From what I could find on the forums, Daz SDK needs QT 4.8.7 X64, but the QT archives have only a X86 ( 32 ) variant stocked. Am I missing something? Is there another place where I could get the needed QT version?
Post edited by frank0314 on
  • Alex@DBGAlex@DBG Posts: 61
    ALso, I have been trying this with VS 22. I have read now that that is not the best way, and I should do it with VS 10?
  • Richard HaseltineRichard Haseltine Posts: 109,488
    You don't need any version of Qt as such, al the needed stuff is in the application or handled by the SDK. There is a fairly lengthy thread on this in the SDK forum.
    I am a longtime UNIX developer and, before DAZ Studio, I hadn't done Win32 in about 20 years. So I joke to myself by saying that I was just too ignorant to know that VS2022 doesn't work, and so did it anyway.
    Seriously, I've been using VS2022 for years, with absolutely no problems at all. I remember that it asked to install one of the runtime libraries, but that was all.
  • Alex@DBG said:
    Hey everyone,
    Based on the number of experienced programmers who are having trouble with the SDK, you've got some challenges ahead. But let's give it a try. But it would be helpful if you could be a little more precise than "I got stuck"...
    To answer your question, yes, it is a good idea to download Qt. All the tools, libs, DLLs and headers are all in the sdk, but it doesn't include Designer, the excellent WYSIWYG GUI editor. You want this.
    Note that your comment about there only being an x86 version, while true, is irrelevant because you're picking up all your binaries from the SDK, not the Qt install. You could use the headers from the Qt install if you wanted to, they're the same as the ones in the SDK, and well designed headers don't have a bitness to them, i.e. it is the compiler that determines whether its 32 or 64 bits, not the header itself.
    I am assuming that you either got compile errors because it couldn't find Qt headers, or you got it to compile, but the liker couldn't find the libs.
    To fix the compile errors, make sure that the SDK include directory is in your solution's include paths (for all combinations of Debug/Release and 23/64 bit), and make sure the #include pragmas in your code are of the form <QtCore/QString>, for example, because the Qt headers are not in the include directory but rather segragated into their own directories. This follows normal Qt convention and the DAZ devs preserved it.
    If it's link errors, make sure your solution's linker options include the x64 lib directory in the SDK, and the input files list all of the libs like dzcore and the Qt libs. Ensure that you use the release versions of all the libraries, not the debug versions... you're not trying to debug Qt here.
    Hope this helps.
    @Richard Haseltine
    Maybe move this to the SDK forum? There are probably many, many people who are unsure about the official Qt distro versus the version shipped with the SDK an they're unlikely to find this thread with the forum search being what it is.
  • frank0314frank0314 Posts: 14,784
    Moved to SDK Developer Forum
    Designer is included with DS, it can be useful for scripting even without the SDK.
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,306
    edited April 2025
    Can you, or anyone, please point out its location? I cannot seem to locate it.
    Edit: Nevermind, Found it. It's not in the SDK, but the DAZ Studio directory for some reason. In that case, I stand corrected... I cannot think of another reason why one would want/need to download the official Qt then.
    Post edited by TheMysteryIsThePoint on
  • Hi gang. Not sure if there's interest in these things but thought
     I'd post anyway about some work I've been doing with Claude and
     DAZ integration. In prepping for that work I've implemented a
     DAZ Studio plugin that exposes a REST endpoint that allows
     external code to execute scripts remotely in Studio. I also
     implemented an MCP server that leverages that plugin. The
     combination of the two, it is hoped, gets us to a starting point
     where we can seriously think about using AI to "drive" DAZ
     Studio and get closer to being able to create scenes by
     describing them.
    Here are the links to the two repos:
    https://github.com/bluemoonfoundry/vangard-daz-script-server
    https://github.com/bluemoonfoundry/vangard-daz-mcp
    What my experience with the plugin repo suggests is that it's now
    entirely possible to create DAZ Studio plugins entirely through
    code assist. In this case, I used Claude Code start to finish to
    create the plugin and have it working in a few minutes of work.
    To that end, I've left the CLAUDE.md files in the repos so if
    anyone else wants to use it and make their own plugins, go for
    it.
    With respect to what is needed to build the plugin, I was able to
    use CMake and VS2022 just fine.
  • TugpsxTugpsx Posts: 838
     describing them.
    it.
    Awesome this should be helpful with my VirtuCam project. It worked well controlling the Daz camera from a mobile device or pad. It was a bit sluggish, but this may prove to be more reliable.
  • @sidcarton1587
    Thanks for this.
    I'll have to try it out before anyone chimes in saying that it is against the EULA.
     describing them.
    it.
    Interesting! So is the VirtuCam a way of touch scrolling on your phone or pad and having the camera move the same way? Like swipe-left and have the camera turn left?
    Yes, it's a project that has been used in Unreal, Blender and Unity. MCasual created a link some years ago that allowed a mobile device or webpage to interact with Daz studio. The technology was adopted for the VirtuCamera project and then enhanced with a few tweaks.
    it worked but was a bit slow since it relied on writing a file to keep track of movement.
    When I connected with the VirtuCam programmer and asked about an API, he was able to create one for us and tests were done in iClone and Character Creator.
    His VirtuCamera project already has a robust front end on mobile devices so it will provide a great front end for the project.
    with this web backend we will need to make connection needed for Daz.
    Years ago others told me there is no interest in this for Daz, but it looks like using a remote or mobile device to direct the camera in Daz may be coming back again.
    BTW the motion control was more of yaw, pitch, roll with forward and backward movement.
    Tilting your phone or iPad up and the Daz camera would follow in almost real time. Tilting left and right and it did the same. Since Daz is not a game engine the need for camera movement like this was not appealing to the average user. Adding the ability to record the movement made it interesting for animation.
    That is really cool. If you think there are improvements that could be made to the plugin to work better for your project let me know.
