Wet Hands and Fingers G8F
SquishySquishy Posts: 719
Perhaps you're washing the dishes. Maybe you dipped your fingers in holy water to make the sign of the cross at church. Maybe you just touched some alien goop and something terrible is about to happen to you. There are plenty of wholesome, totally ordinary everyday situations where your fingers might be glistening, slippery and wet.
A set of DAZ Iray partial material files for Genesis 8 Female, that apply a variety of Top Coat settings using a grayscale mask files to give the effect of wetness on the hands in variety of combinations of one or both hands, including:
- Wet four fingertips
- Wet thumb, index and middle finger
- Whole hand wet
- Arm wet up to the elbow (!)
... for a total of 12 permutations. The material files included will apply any of these on a target figure that already has textures and materials loaded, using the TOP COAT channel of the shader onthe ARMS material selection. Before attempting to use any of these materials, **make sure that your character's ARMS are not already using the TOP COAT branch**, as any of these files will overwrite what is in place on the character in your scene. Since Top Coat is normally only used for just this type of purpose (showing wet coating on an already-textured material) it shouldn't already be in use, but check anyway.
See readme for more info.
Download: RenderHub (login required)
Download: Google Drive
