Does anyone know of any product or outfit with decent, normal looking everyday belted jeans for G8F?
2»
  • HellR4iserHellR4iser Posts: 14
    edited April 2025
    felis said:
    Here it is.
    It was the file size. So I changed it to an accessory instead of a wearable.
    Besides the belt there is a morph for the pants to expand the belt straps. It is in morph loader pro (I was too lazy to move it).
    Let me know if issues.
    You absolute legend - thank you so much. This is perfect.
    Can I ask you how you made it? I've dabbled with Marvelous Designer myself, managed to make some relatively simple pieces of apparel (e.g. skirts, shirts), but this is quite interesting!
    EDIT
    There's a small issue with the folder structure - some files are expected to be in the data\felis\Product\SU_Autumn_Jeans_Belt_G8F, but the folder in the archive is data\felis\Product\SU_Autumn_Jeans_Belt
    Some other files are vice-versa - how I made it work:
    - Rename SU_Autumn_Jeans_Belt into SU_Autumn_Jeans_Belt_G8F
    - Make another folder (at the same leve) called SU_Autumn_Jeans_Belt, then move the UV_Sets folder from SU_Autumn_Jeans_Belt_G8F into it...
    - ...however, file /UV Sets/felis/Base/default.dsf needs to stay in SU_Autumn_Jeans_Belt_G8F
    Post edited by HellR4iser on
  • felisfelis Posts: 5,946
    After the first pack as a wearable preset was to big, I repacked it. And I redid part of the saving, so I must have got something messed up. Will look at it.
    For modelling, I use blender. For textures, I usually make seamless textures in FilterForge, and if a dedicated texture is needed I will use Krita.
