How to fix graft?
How to fix graft?
If I just export the graft alone, the shape is the default. not the one that has been adjusted to the body.
If I export the whole body and the graft, and sculpt the graft, it can't be imported back as a morph.
  • crosswindcrosswind Posts: 9,712
    You export the figure with the geo-graft, sculpt what you want. When import OBJ, in Morph Loader Pro dialogue box, select Primary Figure from Graft (Facet Order) from Load Morph for: (ss1)
    In this way, if you select the figure, it'll create the morph on the figure. If you select the graft, it'll create morph on the graft.
    765 x 610 - 43K
  • MasterstrokeMasterstroke Posts: 2,356
    I did not know that.
    GREAT, thank you :-D
    NP ! blush
