Devious Dolls - Dahlia
I've noticed the following issue.
The first is default Dahlia; I then change the indicated colours (base and translucency) from default to the colours shown, and when rendered I get the seam showing, or what looks like a seam showing.
I'm not sure if it's related, although when I remove any of the normal maps it makes no difference.
If you look at the fourth image, the normal map for the arms is selected as is torso; the arms is the only one that shows as 'being there'; the others have the Daz logo indicating something is wrong; I've included screen shots to show that it is selecting the correct name (Dahlia Torso N has a tick by it), and that the images are present in the folder.
I have uninstalled the product; deleted it, and then redownloaded; I still get the same issue.
  • i wonder if it is that gamma thing again. where studio is interpreting the gamma wrong for one of the textures.
  • nicsttnicstt Posts: 11,715
    Gamma thing?
  • yeah a similar report came up with a different asset. Turned out studio interpreted the gamma setting for of one the textures in the preset incorrectly. There was a fix but I don't recall it since I don't render with studio and it didn't impact me directly.
  • JessaiiJessaii Posts: 845
    I have a feeling its the SSS/Transluceny maps. I did a quick check and the arms are much ligther then the rest of the maps for some reason. I will get an update in for this in hopefully should be fixed soon :)
    TY:)
  • Has anyone been able to apply Dahlias nail colors? I tried twice yesterday but had no luck.
    Hi Silver,
    Im definetely having issues with the iray nail mats. The colors will not apply when selected. If, however, I try to apply the colors in the surface tab, it appears that they apply but when rendered they are very bright and the color is extremely washed out.
  • Updated?
    Updated?
    Not seen an update in the install manager as yet.
  • nicstt said:
    Updated?
    Is this still an issue? I downloaded the character again last Thursday or Friday and still had the same issue with the fingernails. Im thinking its just time to write a ticket.
    nicstt said:
    Updated?
    This has been reported as a bug, as it is also apparent with the default textures.
    I didn't mention the fingernails as I didn't notice that, so raise a ticket.
    Just downloaded an update for this product; hopefully this fixes the issues. yes
    Thanks for the heads up.
    I'm still seeing the error.
