New Year, New Sales Thread: Report Issues Here 2 "Reporting Only"
13031333536100
  • James_HJames_H Posts: 1,091
    The bundle price is the same as  the constituent parts: this seems silly.
    https://www.daz3d.com/fg-24-hour-gym-bundle
  • frank0314frank0314 Posts: 14,734
    edited April 2025
    We'll report it, thanks for pointing it out.
    Post edited by frank0314 on
  • jardinejardine Posts: 1,217
    Richard Haseltine said:
    jardine said:
    'HD Unique Breasts, Nipples and Navels for Genesis 9 Volume 1' does not have a doku entry, or whatever's being used for read mes these days.  click on the link next to the product entry in DIM, and it's not there.
    i can't find the products under Anatomy, either.  and the shortcut the vendor provided to search for the links in Parameters does nothing.  the 'UBNN' search does nothing.
    j
    How did you install?
    via DIM.
    j
  • Richard HaseltineRichard Haseltine Posts: 108,598
    edited April 2025
    j
    via DIM.
    j
    And, with the figure selected, you typing UBNN (actually, I should think UBN would do) in the filter box at the top of the Parameets pane, with the All or Actor groups selected and Show Sub-Items checked?
  • CES3DCES3D Posts: 228
    The Required Products section of the Read Me for 'InStyle - dForce Hot Hoody Texture Add-On' mentions 'dForce Hot Hoody Genesis 9'. What product is this? I've searched, but I can't find anything that matches.
    However, I did find 'dforce - Hot Hoody - Genesis 8' on Renderosity for Genesis 8.
  • 3DMinh3DMinh Posts: 286
    Is this product: https://www.daz3d.com/kuj-headquarters released to day? because it doesn't have the discount with gold star.
  • YacomoYacomo Posts: 45
    While newer 'DAZ Originals' have been discounted, this does not seem to be the case for older items - intended?
    These items from my wishlist all only have the default membership discount:
    https://www.daz3d.com/the-outlook
    https://www.daz3d.com/the-winter-outlook
    https://www.daz3d.com/vintage-hot-dog-cart
    https://www.daz3d.com/barbarian-warrior-outfit-textures
  • Cris PalominoCris Palomino Posts: 12,570
    That was indeed a premature release. It has been corrected though it may not come off the storefront right away.
    We have aasked about this.
  • vwranglervwrangler Posts: 4,976
    FYI, Hanako 9 appears not to have a readme, even though she was released some time ago, judging by her SKU number -- her separate HD shows a 2024-04-04 release date.
    .https://www.daz3d.com/hanako-9
  • On looking up readme's to help decide on a possible purchase, I found none of the 20 product index sku range links (eg 34,000-34,999) I tried here http://docs.daz3d.com/doku.php/public/read_me/index/start worked. I tried low, high & middle ranges to see which worked, and the answer was none. All 20 links I tried returned a 504 Gateway Timeout "The gateway did not receive a timely response from the upstream server or application.".
    Regards,
    Richard
    Regards,
    Richard
    Will send a report.
  • JumbotronJumbotron Posts: 262
    edited April 2025
    Hello,
    Related madness items seem to have an actual minimum price of $3, instead of the $2 that they should have, per sale terms. Can you confirm that this is happening and report the issue then, please?
    2753 x 1669 - 975K
    3499 x 1503 - 706K
    Post edited by Jumbotron on
    I'm getting a min of $2 and maybe some change. I added a bunch to my cart too. Can you give a screenshot of your cart with some items in there, if not already there? That min is in place on PA products so that they will make a little on the product instead of a few pennies, like we were.
    Hi Frank,
    Maybe I'm misunderanding things. What I mean is that if I sort the whole list of products sold in the Related Madness section by ascending price, I get what you can see in the screenshot attached. So, as you can see, there are products that do get a base minimum price of $2. That's why I don't quite understand that there are also products in that section that set their initial price to a minimum of only 3 dollars. Does this minimum price depend on individual artists?
    Also, I don't know if it's because I don't have English as my first language and I'm misunderstanding it, but the "Minimum discounted price of $X" part of the fineprint does not seem to work reliably either. I understand that expression as that any product sold in the respective sections where that minimum discounted price applies shouldn't go below the established price point even after all possible discounts have been applied. However, products in cart from the affected sections can actually go cheaper than the established minimum discounted price. That's why I thought that what that "Minimum discounted price of $X" actually means is the minimum price that a product in an affected section can reach before it gets any additional discounts (like tokens or coupon codes).
    3511 x 1494 - 842K
  • TomhipTomhip Posts: 579
    New items from yesterday appear to be missing from "Still Mad" section, for example "https://www.daz3d.com/mm3d-hero-hd-shapes-for-genesis-9-masculine".
  • tsroemitsroemi Posts: 3,518
    edited April 2025
    Hi mods, I need a little help, have a rather big cart with a number of DOs in as well - it worked just fine with my DO coupon when I initially built it - had to redo it in order to get a gift card first, and now I'm getting 'coupon not valid'. There are no DAZ+ items in the cart, only normal DOs. Can you please make someone fix this quick? Thank you!
    Edit: It's working again now! Seems to have been just a hiccup.
    Post edited by tsroemi on
    Reported
    yes
  • caravellecaravelle Posts: 2,673
    edited April 2025
    The 25% discount on DO wishlist items doesn't seem to work - at least not when you have Premier Gold Star. Then there is only the Gold Star discount of 20%.The 50% on Still Mad items also do not work. See screenshot.
    1212 x 1580 - 551K
    Post edited by caravelle on
    Is that your entire cart?
    We have reported it cause the product you have in cart doesn't seem to be listed in the Still New category..
    j
    via DIM.
    j
    thanks, richard...
    i have them showing up in Parameters now, so that's good.  any idea where the product is parked, though?  i thought "Anatomy" would have made sense, but no.
    j
    Yes. It contains a Still New item as required.
  • XelloszXellosz Posts: 855
    An extra 25% off* Daz Original Wishlist Items With any Still Mad Release is bugged.
    Example:
    https://www.daz3d.com/xi-world-war-2-weapons The full price is $19.99, and I see $9.79. I have a gold star and DAZ plus so that's -10%  and instead of -30%, it should be -50%, DAZ product so -30%  $19,99*0,7*0,5*0,9=$6.29 That's ok so far.
    But I have wishlisted that product, so the -25% is missing.....
    The wishlisted Still Mad Daz originals are not getting the extra 25% off. <= !!!
    It looks as if yesterday's Newly mad items were missed from the still new category. This is being looked at right now, so please try again in a few minutes.
    edited April 2025
    Thank you, but so far nothing has changed...
    EDIT: The problem was solved; I just took another Still New item.
  • barbultbarbult Posts: 26,361
    edited April 2025
    Daz is advertising Premier subscription for less than Daz+ subscription. Is this a March Madness sale or yet another advertising error?
    1427 x 776 - 180K
    Post edited by barbult on
  • butterflyfishbutterflyfish Posts: 1,495
    It's apparently showing you the pro-rated price. Mine says $0.23/month.
    Oh, that's certainly not clear. It doesn't disclose that it will renew at a higher price, does it?
