Transfer Utility bug - G8F/G8M
kaltlandkaltland Posts: 55
edited April 2025 in Daz Studio Discussion
"Favorites" option is not showing up in the dropdown menu within the Transfer Utility's Extended Options. Version 4.23 and 4.21, same problem.
Edit>Figure>Transfer Utility
  • Richard HaseltineRichard Haseltine Posts: 109,541
    Which dropdown? Whata re you expecting to do?
  • kaltlandkaltland Posts: 55
    edited April 2025
    I've done this a few times and I remember it working. I'm trying to transfer a morph from g8f to g8m. I'm using the transfer utility, but nothing appears in the "extended options" section. I've opened daz3d on 2 different computers, with 2 different versions of the application. I can't see "from source/favorites". I've already pressed the favorite "heart" on the morph I want. Thanks
    978 x 1324 - 128K
    Post edited by kaltland on
    So you are trying to select Source Shape? Your screenshots are just showing the dialogue, no active lists, so I am having trouble following. If it is the Source Shape you can always aply it/them to the figure and select Use Current.
  • crosswindcrosswind Posts: 9,749
    You just unchecked some options but didn't select Morph Targets option, that was why you couldn't see Extended Options...
    527 x 794 - 65K
    So, maybe I'm being confusing. My issue is just that my daz3d "transfer utility dialogue" is not showing the options in the "extended options" section like it used to. The morph I want is already favorited in the parameters but I can't select it in the transfer utility because the favorites tab doesn't appear.
    thanks for your patience
    978 x 1324 - 267K
    489 x 653 - 194K
