How to Unparent the object under DzRigidFollowNode and delete DzRigidFollowNode?
Delete all DzRigidFollowNode in the entire scene.
Thanks.
The following is the AI ​​I asked, but it reported an error when running. I gave feedback and wrote it again, but it still reported an error.
// Daz Studio Script// Script to remove all Rigid Follow Nodes (often used for dForce rigid parts) from the scene(function(){    // Get the main scene object    var oScene = Scene;    var aNodesToRemove = []; // Array to store nodes marked for deletion    print( "Starting search for Rigid Follow Nodes (DzRigidFollowNode)..." );    // --- Recursive function to find nodes anywhere in the scene hierarchy ---    function findNodesRecursive( node, targetClass, nodesList ) {        if (!node) return; // Safety check        // Check the current node        // inherits() is the reliable way to check the type, including derived classes        if ( node.inherits( targetClass ) ) {            print( "Found " + targetClass + " node: '" + node.getLabel() + "' (Internal Name: '" + node.getName() + "')" );            // Avoid adding duplicates if somehow visited twice (shouldn't happen with simple recursion)            var alreadyListed = false;            for( var k = 0; k < nodesList.length; k++ ){                if( nodesList[k] === node ){                    alreadyListed = true;                    break;                }            }            if( !alreadyListed ){                nodesList.push( node ); // Add to our list for removal            }        }        // Recurse through children nodes        var numChildren = node.getNumNodeChildren();        for( var i = 0; i < numChildren; i++ ) {            var child = node.getNodeChild(i);            if( child ) {                findNodesRecursive( child, targetClass, nodesList ); // Recursive call            }        }    }    // Start the recursive search from the scene's root node    // This ensures we find nodes no matter how deeply they are nested.    var rootNode = oScene.getRootNode();    findNodesRecursive( rootNode, "DzRigidFollowNode", aNodesToRemove ); // Target class is now "DzRigidFollowNode"    // --- Deletion Phase ---    if( aNodesToRemove.length > 0 ){        print( "\nFound " + aNodesToRemove.length + " Rigid Follow Node(s) marked for removal." );        // Begin undo block - VERY IMPORTANT for safety and user experience        UndoMgr.beginUndoGroup("Remove All Rigid Follow Nodes");        var removalCount = 0;        for( var j = 0; j < aNodesToRemove.length; j++ ){            var nodeToRemove = aNodesToRemove[j];            // Double-check the node still exists in the scene before attempting removal            // (It's good practice, though unlikely to be an issue here)            if( nodeToRemove && oScene.findNodeIndex(nodeToRemove) != -1 ) {                 print( "Removing: '" + nodeToRemove.getLabel() + "'" );                 // Remove the node from the scene                 if( oScene.removeNode( nodeToRemove ) ) {                    removalCount++;                 } else {                    print(" >> Failed to remove node: " + nodeToRemove.getLabel());                 }                 // 'nodeToRemove' variable now points to a potentially deleted object. Don't use it further.            } else {                 print( "Skipping node (already removed or invalid): " + (nodeToRemove ? nodeToRemove.getLabel() : "Unknown") );            }        }        // End undo block        UndoMgr.endUndoGroup();        print( "\nFinished removing Rigid Follow Nodes. Successfully removed " + removalCount + " node(s)." );    } else {        print( "\nNo Rigid Follow Nodes (DzRigidFollowNode) found in the scene." );    }})(); // End of script function wrapper
Script Error: Line 45
TypeError: Result of expression 'oScene.getRootNode' [undefined] is not a function.
Stack Trace: ()@:45
Error executing script on line: 45
Script executed in 0 secs 1 msecs.
