Render Throttle For IRAY
jmucchiellojmucchiello Posts: 985
I recently bought [Render Throttle For IRAY] this and can't get it to work. Whenever I run any of the scripts, Daz stops responding. I've let it sit for an hour. I always have to kill Daz from task manager if I run any of the scripts.
Today, I found this in the log file:
2025-04-03 06:49:32.688 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : Found no environment light and environment dome ground is purely diffuse.
2025-04-03 06:49:32.688 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : This may yield unexpected results. Consider disabling "environment_dome_ground".
I'd love to do something about it, but Daz isn't responding. The entire screen has that gray Not responding look. And yet somehow, it's still "rendering":
2025-04-03 06:49:32.688 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2025-04-03 06:50:07.027 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00007 iterations after 01:49.055.
2025-04-03 06:50:07.040 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 12770 iterations after 06:02.425.
2025-04-03 06:50:44.986 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00015 iterations after 02:27.014.
2025-04-03 06:50:44.997 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 14083 iterations after 06:40.382.
2025-04-03 06:51:20.937 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00031 iterations after 03:02.965.
2025-04-03 06:51:20.954 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 15254 iterations after 07:16.340.
2025-04-03 06:51:52.688 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00063 iterations after 03:34.716.
2025-04-03 06:51:52.695 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 16187 iterations after 07:48.080.
2025-04-03 06:52:22.769 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00127 iterations after 04:04.797.
2025-04-03 06:52:22.777 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 16935 iterations after 08:18.162.
2025-04-03 06:52:57.332 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00255 iterations after 04:39.361.
2025-04-03 06:52:57.344 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 17548 iterations after 08:52.729.
2025-04-03 06:53:37.741 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00453 iterations after 05:19.769.
2025-04-03 06:53:37.755 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 18039 iterations after 09:33.140.
2025-04-03 06:54:19.588 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00681 iterations after 06:01.615.
2025-04-03 06:54:19.595 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 18433 iterations after 10:14.981.
2025-04-03 06:55:03.001 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00937 iterations after 06:45.029.
2025-04-03 06:55:03.008 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 18751 iterations after 10:58.393.
2025-04-03 06:55:48.296 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 01227 iterations after 07:30.323.
2025-04-03 06:55:48.308 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 19000 iterations after 11:43.693.
2025-04-03 06:56:37.530 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 01557 iterations after 08:19.558.
2025-04-03 06:56:37.542 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 19199 iterations after 12:32.927.
2025-04-03 06:57:30.852 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 01923 iterations after 09:12.880.
2025-04-03 06:57:30.864 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 19359 iterations after 13:26.249.
