Dform panel is missing the add node button in DS 4.23 (solved)
FrankTheTank
A product I am trying to use requires that I use the add node button of the dform control panel, but it seems to be missing from DS 4.23. So how do I Add Node now in Dform? This worked in DS 4.16.03 because I used this product then, so it was removed at some point between 4.16 and 4.23.
Post edited by FrankTheTank on
The buttons have been relabelled - you want Add Influence to Selected...
I tried that but it didn't work for this product when I tried it initially. But you are right that is the correct way. This old product has several versions of the installer, one for Poser, one for Daz Studio 3DL, and one for Iray, but for some reason the iRay version is broken. But if I use the installer for 3DL and then retexture it for Iray manually it works. So it was a product issue all along. Thanks Richard.
