Autofit not showing!
Can someone help me how to fix this one
So when i try to use the wardrobe superjeans to G9 the autofit setting won't show but it shows for the other wardrobes
Product: https://www.daz3d.com/genesis-8-male-mega-wardrobe
  • CES3DCES3D Posts: 241
    If the Auto-Fit dialog doesn't appear when you apply different generation clothes directly to the figure from the Content Library, you can manually Auto-Fit by selecting the clothes in the Scene Pane, right-clicking, and choosing [Fit "Clothes Name" To...] followed by selecting the figure.
    598 x 585 - 63K
    763 x 1002 - 148K
  • ObsiObsi Posts: 26
    Tried that too and still not showing!
    I also tried to uninstall and install it but still the same
    I also tried with the same product as you, and the Auto-Fit dialog appeared without any issues. That's puzzling.
    2560 x 1400 - 842K
    2560 x 1400 - 613K
  • crosswindcrosswind Posts: 10,253
    Check some data of the jeans firstly... Just load the jeans into the scene without selecting G9.  From the menu: Edit > Figure > Scene Identification....  check if the data you see is like the one I showed down below.
    2560 x 1392 - 503K
    I'm confused as well, because I used this last month and it works just fine.
     It's the same
    834 x 612 - 107K
    Let's troubleshoot to pinpoint the cause of the problem.
    1. First, open a new scene.
    2. Load Genesis 9 Dev Load into the scene and select it in the Scene Pane.
    3. In the Parameters Pane, check Preferences > Show Hidden Properties from the hamburger button (or the right-click menu of the Parameters Pane tab).
    4. In the Parameters Pane, select Currently Used and check the Properties currently applied to Genesis 9, and see if any unnecessary Properties are applied.
    5. From Daz Studio's Menu bar, select Help > Troubleshooting > View Log File, and check the latest timestamp of the log at this point.
    6. Load the problematic clothing (MEGA Wardrobe SuperJeans) onto Genesis 9.
    7. Check the log again and review the logs after the timestamp you checked earlier. There might be a clue to solving the problem.
    For reference, the log from my environment where Auto-Fit completed successfully is as follows:
    2025-03-23 10:08:57.694 [INFO] :: Prepare asset load (merge): /People/Genesis 8 Male/Clothing/OOT MEGA Wardrobe Male/MEGA Wardrobe SuperJeans.duf
    2025-03-23 10:08:57.694 [INFO] :: Locking viewport redraw...
    2025-03-23 10:08:57.694 [INFO] :: Viewport redraw locked.
    2025-03-23 10:08:58.083 [VERBOSE] :: Native format content directories: 10
    2025-03-23 10:08:58.083 [VERBOSE] :: Poser format content directories: 4
    2025-03-23 10:08:58.083 [VERBOSE] :: Other import format content directories: 0
    2025-03-23 10:08:58.083 [INFO] :: Begin asset load (merge): /People/Genesis 8 Male/Clothing/OOT MEGA Wardrobe Male/MEGA Wardrobe SuperJeans.duf
    2025-03-23 10:08:58.087 [INFO] :: Determining missing assets...
    2025-03-23 10:08:58.137 [INFO] :: Setting textures...
    2025-03-23 10:08:58.177 [INFO] :: Scanning for addons...
    2025-03-23 10:08:58.185 [INFO] :: Creating node geometry...
    2025-03-23 10:08:58.188 [INFO] :: Creating UV sets...
    2025-03-23 10:08:58.188 [INFO] :: Creating materials...
    2025-03-23 10:08:58.189 [INFO] :: Resolving legacy figures...
    2025-03-23 10:08:58.189 [INFO] :: Preparing modifiers...
    2025-03-23 10:08:58.189 [INFO] :: Creating modifiers...
    2025-03-23 10:08:58.238 [INFO] :: Finalizing modifiers...
    2025-03-23 10:08:58.238 [INFO] :: Sorting property groups...
    2025-03-23 10:08:58.238 [INFO] :: Setting up follow targets...
    2025-03-23 10:08:58.238 [INFO] :: Start following: Genesis 9 << MEGA Wardrobe SuperJeans
    2025-03-23 10:08:58.238 [INFO] :: Following started: Genesis 9 << MEGA Wardrobe SuperJeans
    2025-03-23 10:08:58.254 [INFO] :: Finished asset load (merge): 0m 0.170s - /People/Genesis 8 Male/Clothing/OOT MEGA Wardrobe Male/MEGA Wardrobe SuperJeans.duf
    2025-03-23 10:08:58.659 [INFO] :: Unlocking viewport redraw...
    2025-03-23 10:08:58.659 [INFO] :: Viewport redraw unlocked.
    2025-03-23 10:08:58.673 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Fix.dsf
    2025-03-23 10:08:59.129 [INFO] :: Retrieving conversion options...
    2025-03-23 10:09:24.470 [INFO] :: Starting conversion: MEGA Wardrobe SuperJeans >> Genesis 9 :
    2025-03-23 10:09:24.485 [INFO] :: Loaded morph deltas: 0m 0.12s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Clones/CloneGenesis8Male.dsf
    2025-03-23 10:09:24.505 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Pull-R.dsf
    2025-03-23 10:09:24.584 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Pull-L.dsf
    2025-03-23 10:09:24.608 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Pull-Front.dsf
    2025-03-23 10:09:24.620 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Pull-Back.dsf
    2025-03-23 10:09:24.632 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Pockets-FrontOpen2R.dsf
    2025-03-23 10:09:24.643 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Pockets-FrontOpen2L.dsf
    2025-03-23 10:09:24.655 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Pockets-FrontOpen1R.dsf
    2025-03-23 10:09:24.667 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Pockets-FrontOpen1L.dsf
    2025-03-23 10:09:24.679 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Pockets-FrontFilledR.dsf
    2025-03-23 10:09:24.692 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Pockets-FrontFilledL.dsf
    2025-03-23 10:09:24.704 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Pockets-BackFilledR.dsf
    2025-03-23 10:09:24.716 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Pockets-BackFilledL.dsf
    2025-03-23 10:09:24.730 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/pJCMThighSide_85_R.dsf
    2025-03-23 10:09:24.743 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/pJCMThighSide_85_L.dsf
    2025-03-23 10:09:24.758 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/pJCMThighFwd_57_R.dsf
    2025-03-23 10:09:24.771 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/pJCMThighFwd_57_L.dsf
    2025-03-23 10:09:24.785 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/pJCMThighBack_35_R.dsf
    2025-03-23 10:09:24.811 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/pJCMThighBack_35_L.dsf
    2025-03-23 10:09:24.825 [INFO] :: Loaded morph deltas: 0m 0.9s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Open-6.dsf
    2025-03-23 10:09:24.838 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Open-5.dsf
    2025-03-23 10:09:24.850 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Open-4.dsf
    2025-03-23 10:09:24.863 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Open-3.dsf
    2025-03-23 10:09:24.875 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Open-2.dsf
    2025-03-23 10:09:24.886 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Open-1.dsf
    2025-03-23 10:09:24.905 [INFO] :: Loaded morph deltas: 0m 0.10s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/FitStyle-Tapered.dsf
    2025-03-23 10:09:24.922 [INFO] :: Loaded morph deltas: 0m 0.11s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/FitStyle-Loose.dsf
    2025-03-23 10:09:24.936 [INFO] :: Loaded morph deltas: 0m 0.9s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/FitStyle-Foldy.dsf
    2025-03-23 10:09:24.949 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/FitStyle-CrotchDown.dsf
    2025-03-23 10:09:24.966 [INFO] :: Loaded morph deltas: 0m 0.12s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/FBMPortly.dsf
    2025-03-23 10:09:24.982 [INFO] :: Loaded morph deltas: 0m 0.12s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/FBMMichael8.dsf
    2025-03-23 10:09:25.000 [INFO] :: Loaded morph deltas: 0m 0.12s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/FBMEmaciated.dsf
    2025-03-23 10:09:25.017 [INFO] :: Loaded morph deltas: 0m 0.12s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/FBMBodybuilderSize.dsf
    2025-03-23 10:09:25.034 [INFO] :: Loaded morph deltas: 0m 0.12s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/FBMBodybuilderDetails.dsf
    2025-03-23 10:09:25.046 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Down-R.dsf
    2025-03-23 10:09:25.058 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Down-L.dsf
    2025-03-23 10:09:25.069 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Down-Front.dsf
    2025-03-23 10:09:25.092 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Down-Back.dsf
    2025-03-23 10:09:25.104 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Bulge.dsf
    2025-03-23 10:09:25.116 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-ThighR.dsf
    2025-03-23 10:09:25.138 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-ThighL.dsf
    2025-03-23 10:09:25.149 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-ShinR.dsf
    2025-03-23 10:09:25.161 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-ShinL.dsf
    2025-03-23 10:09:25.172 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-KneeR.dsf
    2025-03-23 10:09:25.182 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-KneeL.dsf
    2025-03-23 10:09:25.195 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-Hips.dsf
    2025-03-23 10:09:25.206 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-HipR.dsf
    2025-03-23 10:09:25.219 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-HipL.dsf
    2025-03-23 10:09:25.231 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-Glutes.dsf
    2025-03-23 10:09:25.245 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-GluteR.dsf
    2025-03-23 10:09:25.257 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-GluteL.dsf
    2025-03-23 10:09:25.268 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-FootR-Width.dsf
    2025-03-23 10:09:25.279 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-FootR-Outer.dsf
    2025-03-23 10:09:25.290 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-FootR-Inner.dsf
    2025-03-23 10:09:25.301 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-FootR-Height.dsf
    2025-03-23 10:09:25.316 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-FootR-Front.dsf
    2025-03-23 10:09:25.326 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-FootR-Back.dsf
    2025-03-23 10:09:25.338 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-FootL-Width.dsf
    2025-03-23 10:09:25.350 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-FootL-Outer.dsf
    2025-03-23 10:09:25.361 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-FootL-Inner.dsf
    2025-03-23 10:09:25.372 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-FootL-Height.dsf
    2025-03-23 10:09:25.384 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-FootL-Front.dsf
    2025-03-23 10:09:25.395 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-FootL-Back.dsf
    2025-03-23 10:09:25.407 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-CrotchWidth.dsf
    2025-03-23 10:09:25.419 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-CrotchHeight.dsf
    2025-03-23 10:09:25.436 [INFO] :: Loaded morph deltas: 0m 0.11s - /data/outoftouch/MEGA Wardrobe G8M/MEGA Wardrobe SuperJeans/Morphs/outoftouch/Base/Adjust-All.dsf
    2025-03-23 10:09:34.377 [INFO] :: Finished conversion: MEGA Wardrobe SuperJeans >> Genesis 9 :
    2025-03-23 10:09:34.377 [INFO] :: Connect base morphs: Genesis 9 << MEGA Wardrobe SuperJeans
    2025-03-23 10:09:34.402 [INFO] :: Base morphs connected: Genesis 9 << MEGA Wardrobe SuperJeans
    2025-03-23 10:09:34.402 [INFO] :: Creating morph projection map: Genesis 9 << MEGA Wardrobe SuperJeans
  • Richard HaseltineRichard Haseltine Posts: 111,382
    So AutoFit works for some things but not others?
    edited March 2025
    My friend manage to fixed it! Thank you so much tho
    My sister was doing something with the jeans last night then daz crash and my friend suspected that it might have something to do with it.
    She was trying to do this when daz crash
     https://www.daz3d.com/forums/discussion/698211/create-or-transfer-open-fly-morph-for-g8-male-mega-wardrobe-jeans?srsltid=AfmBOoo22bVkjo384Fwe6dwMEmKg6v9Q5_ZOtvKuBV0EDAqePrk2_pb3
    Post edited by Obsi on
    yeah it work for the others but the jeans.
    tho it was now fixed
    I'm happy you got it fixed! You're lucky to have such a good friend.
    Oh, that was my tutorial hoho~  If your sister encountered a DS crash when saving the figure asset of those jeans, the metadata might've been partially saved....
    I suspect that the inconsistency of Preferred Base for two versions of figure assets (with different vendor names) in cms might be the culprit ~~devil
