How do I make clothing not follow figure when I have a morph activated?
i'm not sure my title made sense, it's hard to put into words. But here goes. I have Dforce to Morph and after I have posed and run the sim I save the sim as a morph. However, when I repose and activate the morph, the clothing follows the figure and buggers the fit. How do I stop that happening?
  • crosswindcrosswind Posts: 9,618
    edited March 2025
    The figure has to be at world center before using dForce to Morph script... otherwise you'll have the above issue.
    Edit:  Wait a min... you reposed the figure ?  The saved morph is only for the pose before you run dForce2Morph.... What did you want to be exactly ?
    Post edited by crosswind on
  • LorraineLorraine Posts: 906
    Hi crosswind. Yes I reposed the figure to the pose I used for the sim and then morph. I want to be able to load the figure, load the clothing, pose the figure, then activate the morph associated with the pose. I have several purchased items in my runtime that do this without problems and I'd like to do the same with my morphs.
    Oh... if so, there should be no problem. Just do it with dForce2Morph script when the figure locates at the world center.
    Thank you! That worked. I had forgotten that my figure was slightly off world centre and that's what borked it. Everything works as I want now. You are so helpful :)
    No problem ~ Have fun ! blush
