What the heck is this?
I have no idea where the crest on the head is coming from.  Its on all of the characters.  I have uninstalled everything, deleted all files and re installed. But yet, I have crests on all of my heads.  HELP! Please.
  • IceCrMnIceCrMn Posts: 2,323
    I ran into this with a different morph. I didn't figure out how to fix it, but I did learn a workaround.
    In you documents folder Daz Studio keeps a data folder of custom changes.Move the folder out of there to someplace else and see if that works.
    in C:\Users\silverriverjewlery\Documents\DAZ 3D\Studio\My Library look for "data" folder.Move it out to someplace like your desktop for safe keeping.See if your characters are fixed. :)
  • Great thank you!  I will give that a try.  Have to run and pick up the car from the shop then will see if this works.  Really really weird lol.
  • Open the Parameters pane and click on the Currently Used group in the left-hand column, the morph causing the issue should then be one of those shown on the right of the pane. Click the gear on its slider, click Parameter Settings, set the default value to 0 (and the current value to 0), Accept, then go to File>Save as>Support Assets>Save Modified Assets, make sure only that morph is listed and click Accept.
  • BejaymacBejaymac Posts: 1,949
    As it's Genesis then expect to see the Genesis.dsf in the list as well, it doesn't have the new surface system that was introduced with G2F, and as such is always being modified when ever you load it into a scene.
  • Thank you!  It was actually happening on all of the genesis figures genesis, genesis 2 and 3 as well as the kid and the men.  Am off to have a look now that I have an idea of what to look for.  Thank you!
  • kaotkblisskaotkbliss Posts: 2,914
    That's either the fin from the sharecg morph set, or the fin from the creature creator. I've seen it before in one of the morph packs just can't remember which one exactly.
  • IceDragonArtIceDragonArt Posts: 12,838
    edited September 2015
    That should help narrow things down thank you!
