Material Suit Script Error
Trying to use the Material Suit Apply H.Preset script and I can't get it to work with any presets I have saved myself.
It always gives this error: Unknown figure in hierarchical material preset: (path to preset). Log is no help.  Just about any other preset works (that I have tried anyway, even ones with custom eyebrow figures and all kinds of stuff).  But nothing I save, even stripped down to the basics will work.
Anyone else run into this and if so how did you solve it.
  • Richard HaseltineRichard Haseltine Posts: 111,444
    So, is it the correct figure and are the things you are applying it to parented correctly (usually to the figure).
  • evilded777evilded777 Posts: 2,546
    If I understand the question correctly: Yes. I have tried both G8 and G8.1 males, with either a G8 Male or G8.1 Male Material Suit parented to G9. Like I said, this works fine with virtually any H.Preset except ones I have saved myself.
    Does Smart Content, with Filter By Context active, give the expected results with a Genssi 8/8.1 figure selected?
  • crosswindcrosswind Posts: 10,276
    edited March 2025
    Well, unfortunately the script checks if the path of Asset ID in H.Mat Preset file is under the sub-folder of People/Genesis 8 Female or People/Genesis 8 Male... If it's not, it'll throw you error message, like the path in (ss1)
    If you simply change it to the one in (ss2) with Notepad++, it'll work ~~ no matther where the H.Mat Preset really locates.
    But the simpler way can be: directly save the H.Mat Preset into the folder of People/Genesis 8 Female or People/Genesis 8 Male in your Daz Library. You can create a sub-folder of Presets there if you'd like.
    Edit: I rarely use Material Suit but Cayman Studio's Legacy series. But I think we may ask @RiverSoftArt to improve the script to cancel the path check ~~
    1235 x 695 - 50K
    1235 x 693 - 49K
    Post edited by crosswind on
    How did you catch that? I was going crazy. But it makes perfect sense, since I store all of my characters in a different directory path.
    Yeah, performing more experiments can usually help with finding out the culprit ~~ devil
