NVIDIA driver certification
All,
I know that DAZ has a small team, and testing all the drivers that are released shouldn't necessarily fall on DAZ. I just have a suggestion, when a new studio driver is released by NVIDIA Is there a set of stability test cases you guys run on those or do you do that only in preparation for a release? I've run into a lot of stability issues with the latest Nvidia driver, and I had to roll back and I had a hard time finding A driver that's stable outside of what was suggested at the very release of this version of Daz. That driver is a bit outdated at this point. It would be nice if new drivers that come out Can go through some sort of certification process. The only reason why I suggested here is because DAZ usually gets blamed And a lot of time is spent on the forums by people Troubleshooting issues that turn out to just be driver related. It doesn't make for the best experience and while it's not DAZ's fault, it does end up getting a lot of blame which ends up leading to a negative impression of the product as a whole. Also, it's very difficult to find the correct driver that was released with a particular version. Maybe I'm the only one, but I find the separation of the release announcement And the Nvidia driver page Unnecessarily complicated for the average user.
These are just suggestions to help improve product perception . You could even farm this out to the community In exchange for some coupon for their work.
Please take this suggestion in the way it was intended (to help Daz and others here) thanks for your consideration!
At the very least pinning the Currently recommended driver for the latest release In the forums, Would be a huge step IMO!
https://www.daz3d.com/forums/discussion/666006/daz-studio-4-23-0-x-highlights#latest
https://www.daz3d.com/forums/discussion/666011/daz-studio-4-23-0-x-nvidia-iray#latest
both should give the current minimum driver version.
