[Released] Ancient Sigil Portal Builder [Commercial]
Lantios
https://www.daz3d.com/ancient-sigil-portal-builder
Unveil the mysteries of ancient magic with the Ancient Sigil Portal Builder, a powerful builder designed to craft breathtaking mystical gateways, forgotten temples, and enchanted ruins. Perfect for epic fantasy scenes, cosmic adventures, or arcane storytelling, this set brings your imagination to life with unmatched detail and flexibility.
The set lets you create mesmerizing portals that resonate with ancient power. Choose from several portal options including a Closed Portal, a Mid-Activation version, and a captivating Portal Tunnel that transports viewers to otherworldly realms. These elements bring instant drama and narrative depth to any scene.
Construct your mystical environment using modular architectural elements. Combine Wall (A-D) subsets with the Tiled Floor elements and a variety of mystical Cubes and Broken Cubes, including ivy-draped versions that seamlessly blend into ancient ruins or overgrown temples. Whether crafting a majestic ceremonial site or a long-lost sanctuary, these pieces allow endless possibilities.
Keep in mind the displacement options are set to a high level to provide the crisp carved details seen in the promos. Lower the subdivision levels with the included Shader presets, or disable it altogether in case it impacts your render speeds. The included !Temple Portal Main and !Well House Main are from the promo shots, to help you jumpstart your scenes!
Open doors to untold adventures and breathe life into your fantasy worlds with the Ancient Sigil Portal Builder. With its stunning visuals and infinite customization, this set transforms your renders into epic, immersive experiences.
Portal Activated
Mid Activation Portal
Closed Portal
The Witches' Well
Entering The Portal
Available elements in kitbash (the broken cubes, divided cubes, floor pieces and ivy have each piece as an individual model, so you can use them to create debris, floating pieces, your own custom ivy growing along walls and your own custom floor subsets)
Lit Cube Details
Closeup Details of Portal
Availalble Subsets
Looks great!
Thank you!
It's out now :) for anyone else interested!
Got it - I'm loving this stuff :)
AWESOME! And it fit perfectly into my shopping cart. :)
Got it, looks great
Thanks guys! Glad you liked it :)
