How to install Genesis Generation X2?
I have DAZ installed on an external hard drive
And for some reason when I try to install Genesis Generation X2 my DAZ just doesn't see it. Usually if I can't install I just throw the files from the archive into the folder but in Genesis Generation X2 there is no directory familiar to me and I don't understand how to install it please help.
  • crosswindcrosswind Posts: 10,289
    If you installed it with DIM, the plugin DLL file will be installed into you DS application folder as long as you correctly configure the path in DIM > Advanced Settings > Applications.
    Then via DS > Help > About Installed Plugins, you should be able to see GenX plugin is enabled. Then you can find the plugin under Window > Panes (tabs)...
    674 x 696 - 70K
    721 x 959 - 80K
    727 x 456 - 80K
  • PadonePadone Posts: 4,339
    You may also want to check that it works fine with 4.23, as the latest update is dated 2017.
    http://docs.daz3d.com/doku.php/public/read_me/index/18321/start
    Right ~ the plugin works well with DS 4.23+ ...
