Is it possible to intriduce an offset between the recurrence of a pattern on the same surface?
Hi! I have a pattern on a cloth on which I applied a pattern and a tiling 3x3. For now, my pattern is repeted without any "shifting", i.  e. the top pattern is exactly abouve the bottom pattern. I wonder if it would be possible to introduce an offset only on one of the recurrence, in order for the bottom pattern to be shifted compared to the top pattern:
Is there a way to do that, please?
Thank you in advance!
  • crosswindcrosswind Posts: 10,285
    Nah... I'm afraid you have to modify the texture maps...
  • GordigGordig Posts: 10,807
    Alternately, you could shift the UV mapping.
  • yuyu.atemyuyu.atem Posts: 493
    Oh, it's too bad! Ok, I think that in my case, the best way would be to shift the texture map because shifting the UV would also shift the normal map...
    Thank you very much! laugh
