update, latest Nvidia Studio driver seems to work on animated image ser
WendyLuvsCatz
this is now affecting my ability to use other software
I need Nvidia Workbench but D|S has memory issues with later drivers rendering animations
and worse there are security issues with the driver 561.09 I am forced to use in order to render image series animations in DAZ studio
not all D|S users just do single images
I am going to try the latest driver in my other software that needs it
will see if I need to roll back for DAZ studio later
will update my post probably tomorrow
This is not soemthing that the daz developrs can do - it is the nVidia drivers and the nVidia rendering application
well the latest Studio driver seems to not ramp up VRAM
just did 1K frames with it staying more or less the same each frame
this driver doesn't seem stable though
rendering in iray my monitor which is plugged into the card blackscreened but fortunately it recovered and it kept rendering
the other monitor using the mobo integrated graphics remained on
also the viewport is exceedingly laggy
The blackscreening might be a PSU problem. It sounds exactly like the problem I was having until I replaced my PSU. After that I never had another monitor blackout again. Something to consider if you haven't already.
the latest one got uninstalled and rolled back pretty fast
it went nuts completely ignoring my MSI Afterburner curve settings ramping up heading to a blackscreen if I hadn't stopped the program I was using in time
wasn't going to test it on DAZ studio too
