I tried the Yellow AI to make a male k-pop idol
ibr_remote aka infinity10
The new AI add-on by Yellow allows generation of shapes from text input. I used the promotional free 10-token code and tried it out. My first attempt failed because the morph could not be loaded. I tried again and got a shape which I then customised with a mash-up of 3rd-party materials and a couple of my own morphs. Not too bad a result for a test run.
The way I understand it is the generated Full Body Morph is stored online and retrieved through the Yellow add-on (you find it in the Window menu inside Daz Studio). So I would need to pull down the generated morph from Yellow each time I want to use it.
This is my test of the Yellow AI shape generator inside Daz Studio, fully rendered.
Pretty good results. My only test has failed unfortunately.
did those veins on the chest come from the AI or did you put them there? 'Cause they look slightly out of place their imho
I thought my first prompt failed too. It didn't apply. I clicked off it and on again a couple of times until it worked.
Those veins are from a commercial vascularity product, and I agree they look a bit unusual. The Yellow AI add-on only generates the shape. We have to add materials and other morphs if we want to fine tune the look.
Moved to Art Studio
Thank you and sorry for the bother...
