GPU Rendering not Working Daz 4.23
Hello Everyone,
I have set up a new Computer and try to get the GPU Rendering working in Daz 4.23
The problem i have, is that the CPU works for Rendering but Daz does not recognize the GPU. Attached are the setting i use in Daz. Anyone knows a solution to this problem?
  • Richard HaseltineRichard Haseltine Posts: 109,668
    You cannot paste images into posts, you need to attach them (or host theme xternally and paste a link, which you can also do to the attachment as long as it remains attached).
    I can see your image in the edit/quote window - you have a 50x0 card, and those cannot be suported in DS 4.x.x.x due to a chnage in the way nVidia compiles the binaries; we are stuck waiting for the next major version of Daz Studio unless there is a way to export MDL and use a stand-alone version of Iray (apparently Iray Server doesn't help). Sorry that it is bad news.
  • thank you very much for your quick responce. In the end i thought that it could be something like this. Yeah i have two 5090 cards, so i guess i have to wait and use the CPU for renders in the meantime.
    Thanks again and i will attach the images in the future.
