[Released] Word Tattoo Pro for Genesis 9 [Commercial]
RiverSoft Art
Word Tattoo Pro for Genesis 9 allows you to quickly create custom Word Tattoos for your Genesis 9 characters! Type in your tattoo message, set a few options, and Word Tattoo Pro automatically creates a layered image and applies it to the correct Iray or 3Delight materials and color channels! Word Tattoo Pro is extremely customizable allowing you to specify the location and orientation, font and font styles, opacity and crispness of your tattoos. For Finger Tattoos (or their toes and fingernails), Word Tattoo Pro automatically aligns the text so that each character, word, or line is placed on a separate finger in the correct location and orientation.
Word Tattoo Pro requires no external programs. For Windows ONLY.
Features
- Easily create custom Word Tattoos on any Genesis 9 character material
- Near-real time Previews*
- Specify exact position and orientation of your Word Tattoos
- Use paths with Word Tattoos (includes 25 paths)*
- Easily apply custom Word Tattoos with Automatic Placement to the fingers, fingernails, toes, and toenails
- Use multiple characters, words, or lines with Automatic Placement for Fingers, Toes, Fingernails, and Toenails*
- Create single line or multiline tattoos with left, center, and right justification and custom line spacing
- Use Unicode alphabets for text in Japanese*, Chinese*, Korean*, Greek, and more
- Uses all Fonts available on your system
- Change Fonts, Font Sizes, Colors, and Styles (bold, italic, and underline)
- Change the opacity and crispness to give a faded look to your custom word tattoos
- Supports Iray and 3Delight materials
Word Tattoo Pro does not support wrapping your tattoos around the textures so you must avoid the edges of the materials in order to see the complete word tattoo.
* New to Word Tattoo Pro
And it is released!
Bought it and installed it through DIM, but can't make it work. I select my Genesis 9 figure and this is the error code I get when trying to start it:
2025-02-28 15:08:43.815 [DEBUG] :: Generation 9
2025-02-28 15:08:43.817 [DEBUG] :: InitBodyParts2023 [object Object] 9
2025-02-28 15:08:43.889 [DEBUG] :: GetSystemFonts: tempfile /Users/***/Library/Application Support/DAZ 3D/Studio4/temp/d14.txt
2025-02-28 15:08:43.890 [DEBUG] :: args /Applications/MacOSXGenerateTattoo.app/Contents/MacOS/MacOSXGenerateTattoo,getFont,/Users/***/Library/Application Support/DAZ 3D/Studio4/temp/d14.txt,DONOW
2025-02-28 15:08:46.728 [WARNING] :: Script Error: Line 1323
2025-02-28 15:08:46.730 [WARNING] :: TypeError: Result of expression 'this.wCameraControls' [undefined] is not an object.
2025-02-28 15:08:46.732 [WARNING] :: Stack Trace:
<anonymous>()@/Users/***/daz3d/My DAZ 3D Library/Scripts/RiverSoft Art/Word Tattoo/Word Tattoo Pro for Genesis 9.dse:1323
2025-02-28 15:08:46.740 [INFO] :: Error in script execution: /Users/***/daz3d/My DAZ 3D Library/Scripts/RiverSoft Art/Word Tattoo/Word Tattoo Pro for Genesis 9.dse
It's on Mac OS.
That is strange. Could you post the log from when the script started until this?
I've updated the log above with everything from when I started the script. I've also tried to reinstall it twice, but with the same result. Can also test it on my PC on Monday and see if I'll get the same result there.
The error messages I'll get in DAZ are the following:
"Could not start Word Tattoo. Please check your installation."
"An error occured while reading the file, see the log file for more details."
Strange. I am going to make you a debug version and PM you.
Sorry, no debug version (yet). It looks like it is both a developer problem (me) and an installation problem (Daz). Debugging...
If you don't find any obvious error it could also be my installation. I was just going to use V3Digitimes filatoon shader converter and got an error that it couldn't find the shaders, even if the shaders are exactly in the directory where it was looking for them. I think that product has worked for me before and just stopped working now, or I could remember wrong. If it worked before it could be that something suddenly got wrong with my Daz installation.
Edit: I could remember it a bit wrong. The problem with having 2 computers for Daz.
Did you use DIM or Connect to install? If it was the latter, uninstall and use DIM to install.
I use DIM to install everything. I did a clean-up though a week ago and went from almost 1000 down to 200 installed items. Might be that something happend then. I might try to uninstall the rest of the items too, reinstall Daz and start over from clean state. Will test Word Tattoo Pro on my PC later today though.
The Mac errors are on my end (and configuration on Daz). Still working on it.
Thanks RiverSoft. Tried it on my PC today and it worked perfectly. Great product, easy to use and the paths are a great addition when you don't want the tattoo in a straight line.
I am glad you like it! When I have a potential fix on the mac, I will reach out. Hopefully, you could test it?
It is great and works with FilaToon.
Awesome! I am glad you like it. Thank you for sharing the information and the image!
Thanks, @RiverSoft Art,
It was just a first test. I plan to make more renders, when I will have a spare time.
It is a lot of fun testing different fonts and placement on the character.
I love it! Thanks for sharing @Artini
Thanks. Great product. I am enjoying it very much.
Just one more example...
LOL. You do look like you are having fun! Have you tried any of the Automatic placement surfaces?
Thanks again.
I have not tried any of the Automatic placement surfaces, yet.
Will need to take a look on them - so many things to try.
I'm having the same errors with this. Using a MAC.
For now, I would recommend returning Word Tattoo Pro if you are trying to use it on a Mac. I am sorry.
