New Medium Dark theme for Daz Studio and 2 Ultrawide layouts
MattymanxMattymanx Posts: 6,996
edited February 25 in Freebies
Here is my new Ultrawide layout for Daz Studio and my new medium dark theme to go along with it.  The layout is intended for ultrawide screens which are typically 3440x1440 but it should be ok on a 4K display.
Alternate version thats been tweaked
Post edited by Mattymanx on
  • Mattymanx Will this update fit into an screen size of 3840x2160?
    This is a flat screen type, not curved.
  • MattymanxMattymanx Posts: 6,996
    I cannot test that screen resolution but it should fit.  you will have more space top and bottom then I do.  My screen is flat.  Not sure if flat or curved matters.
  • Halcon BlueskyHalcon Bluesky Posts: 682
    Mattymanx What kind of OS you have Windows 10 or 11?
    Either versions can be accessed via shortcut, Hold Win key and press I letter  to access the settings page.
    Click on System at the left Pane, then click Display.
    Over there, you will see Scale & layout, Display Resolution is visible; you can see clearly what is the Recommended Resolution for your Screen Monitor.
    Tha'ts pretty simple, no rocket science. smiley
    Windows 11 Pro
    My screen resolution is 3440x1440 (Ultraiwde monitor)
    Scale is 100%
    .Mattymanx I see 3 zip files, which one I should download?
    One is a color theme, the other two are layouts.  Download all 3 I guess and decide which of the two layouts works best for you.
    Just dont forget to save the layout and color theme you are using incase you dont like these in the end.
