Error message when trying to load Roller Blades product.
[Error message when trying to load Roller Blades product.] It said an error message occurred and to look to the log for more details. but all I found was this:
2025-02-28 11:19:49.402 [INFO] :: Begin asset load (merge): /People/Genesis 8 Female/Clothing/Tentman/Roller Blade/Roller Blade Blade.duf
2025-02-28 11:19:49.402 [WARNING] :: \src\sdksource\cloud\dzcloudtasknotifier.cpp(201): Invalid file header for encrypted file: "F:/My Daz Stuff/Applications/Data/DAZ 3D/My DAZ 3D Library/data/cloud/1_80682/people/genesis 8 female/clothing/tentman/roller blade/roller blade blade.duf.enc"
2025-02-28 11:19:49.402 [ERROR] :: Open Stream Error: No stream for CloudFile: F:/My Daz Stuff/Applications/Data/DAZ 3D/My DAZ 3D Library/data/cloud/1_80682/people/genesis 8 female/clothing/tentman/roller blade/roller blade blade.duf.enc
2025-02-28 11:19:49.402 [ERROR] :: Open File Failed - Could not read file: /People/Genesis 8 Female/Clothing/Tentman/Roller Blade/Roller Blade Blade.duf
2025-02-28 11:19:49.449 [WARNING] :: Error loading asset: F:/My Daz Stuff/Applications/Data/DAZ 3D/My DAZ 3D Library/data/cloud/1_80682/people/genesis 8 female/clothing/tentman/roller blade/roller blade blade.duf.enc
Operation failed
2025-02-28 11:19:49.761 [INFO] :: Unlocking viewport redraw...
2025-02-28 11:19:49.761 [INFO] :: Viewport redraw unlocked.
I tried reinstalling the rollerblades product, but the same message occurred.
help?
  • SofaCitizenSofaCitizen Posts: 2,145
    edited February 2025
    That looks like a broken/corrupted Daz Connect product install.
    Assuming that the product in question is Roller Blade for Genesis 8 and 8.1 Females then I can confirm that it appears to work when installed via DIM (Daz Install Manager) as per attached image. You can try completely uninstalling it via Connect and then installing via DIM to see if that fixes your issue. If so, you can raise a support ticket to report the Daz Connect version as broken.
    800 x 675 - 54K
    Post edited by SofaCitizen on
  •  yeah, that's the one. and the connect one now refuses to uninstall itself and stuff... looks like I have to manually delete it and then try to reinstall it again.
  • So you right-click on the product container (not one of the files) and there is no Uninstall option?
