Did we lose ERC-Freeze? [SOLVED: Found it]
Eustace ScrubbEustace Scrubb Posts: 2,731
edited February 2025 in Daz Studio Discussion
I'm trying to load a home-made morph to one of my figures, and I can change the shape, and adjust the rigging, but I can't find the "ERC-Freeze" function to lock the adjusted rigging to that shape.  Was it moved, or renamed, sometime in the past few months?
Post edited by Eustace Scrubb on
  • crosswindcrosswind Posts: 9,752
    In Parameters pane, right-click to turn on Edit mode. Then right-click on the morph slider to ERC Freeze.
    Yeah, that's where it used to be, but I'm not seeing it.  Did I turn off the wrong plug-in, or is there a glitch I don't know about in this version?
    Must have been a plug-in I'd turned off (I was trying to streamline the memory usage for shaders), because it's working again.  Thanks!
  • Beta or General Release? There was an issue affecting the ordering of menu entries for some menus in the last build, corrected in the latest (though you may want to run Window>Workspace>Update and Merge Menus to be safe).
