DAZ using CPU not GPU
Hi everyone, I recently bought a new computer and installed Daz
But when rendering I found that Daz only used my CPU instead of GPU
If I go to "Render Settings" and turn off the CPU
It will become completely unrenderable
My graphics card is the new 5070TI
I have confirmed that the drivers are installed
In the Daz log file, there is "There is no CUDA-capable GPU available to the iray"
I would like to ask what should I do?
  • Unfortunately the 50x0 cards require a new version of Iray, and the new version of Iray requires a new version of Daz Studio - it is not possible to integrate it into Daz Studio 4.x.x.x. You may be able to use a local installation of Iray Server as a go-between, but until the next major vesion of Daz Studio is avaialble you will not be able to render inside the application using your GPU.
  • TheKDTheKD Posts: 2,711
    edited February 2025
    Daz should have a banner on their main page warning users that the software will no longer work with the current technology IMO. Save people that use their PC just for things like daz studio the headache of buying an expensive paperweight lol.
    Post edited by TheKD on
  • ArtRouladeArtRoulade Posts: 44
    edited March 2025
    Iray Server won't help here as the Iray version in DS 4 only talks via the bridge with the matched version in Iray Server and newer versions are ignored. Iray Server would also use the same Iray version and falls back to cpu rendering mode.
    Post edited by ArtRoulade on
