Why do my Big Cats 2 look so bright?
Kevin Rye
I have a relatively dark scene. It's a dimly lit wooded area. I have some leopards in the mix. I don't know what it is but they look so bright compared to everything else in the scene. They look like they're glowing in the dark. I have the LAMH Real Fur for Big Cats 2 applied. I've tweaked all kinds of settings on the leopards, but nothing seems to make them look darker, less reflective. Do I tweak something on the leopard, or on the LAMH? What am I missing? I’m looking for something like the SSS 50% you’d apply to a human figure.
Do your lights have shadows activated? From my experience LAMH-Fur seems to be selfglowing when exposed to non-shadow-lights.
Most of the time, I use Area-Lights with activated shadows, Fall-Off and a high sampling rate (96 - 128). That increases the rendertime, but the quality is worth it. Just my opinion. ;-)
Have you tried lowering the Ambient setting for the fur. Going by the light on the arm of the leading figure they are emmitting light :)
Strange, the ambient setting for "SkinFace" and "SkinBody" is set to 0. I'll see if I can tweak the shadow settings on the point lights I have around.
Ah, it wasn't the lights afterall.... I had to select SkinBody under the LAMH asset and not the leopard itself, then drop the Diffuse stregnth. It wasn't intuituve since the Surfaces tab appears blank when selecting LAMH_Leopard. You have to expand LAMH_Leopard in the scene tab, and select the skin, then go to the Surfaces tab.
You can see the difference in the test render. The head is seperate, so you can see the contrast between the body and the head.
Thanks.
