What happened to properties?
I used to be able to edit properties of slider values by clicking on the cog symbol > properties and edit the max, minimums and increment values etc. Now all I see is Favorites, lock, Hidden and reset value which are all useless and redundant when you literally have the lock and favorite toggle symbol right next to the cog.
All I want to to do is change the exposure increment to 0.1 instead of the ridiculous 1.0 default.
Post edited by Rodrij on
Parameter Settings are not exposed on some propeties where they are present between sessions but do not carry adjustments over, to avoid potential confusion. You can enable them through Window>Workspace>Customise. by dragging the command from the left into the relevant context menu(s). This has been the case for soem time, and was discussed at length when it was introduced.
https://www.daz3d.com/forums/discussion/658641/
