Looking for layered shorts over leggings. Both Free and Buyable products is fine.
Sailoraurora17_ad2c0753ab
in The Commons
So I'm looking for loose shorts that can go over leggings... the ones I've got and looked at all ended up being too tight and way too short to the point that they might be called hot pants instead. and those shorts I have tend to clip through the leggings. :(
I don't mind whichever model it is for, as I've got the scripts that allow me to import clothing between all models.
For an image to show what I mean, I'm thinking of something like this: https://www.amazon.com/Hotfiary-Waisted-Running-Athletic-Leggings/dp/B0CW3D89ZC?th=1
https://www.daz3d.com/dforce-bs-pajamas-set-for-genesis-9 add a smoothing modifier and set collision item to leggings
hmm. yeah that looks like it'd work. thanks.
I have found on occasions that if I fit the outer layer to the inner layer of clothes instead of the character, there's enough room without there being an issue.
So, try fitting your shorts to the leggings instead of the character. It may be good.
Won't help with the length though... Hmm.. Maybe remember the idea for the future.
OK, try again. These may do: https://www.daz3d.com/dforce-homebody-for-genesis-8-females and may need to be fitted to the leggings.
Regards,
Richard
How about this?
https://www.daz3d.com/dforce-active-wear-for-genesis-9
https://www.daz3d.com/dforce-active-wear-textures
https://www.daz3d.com/dforce-urban-society-outfit-for-genesis-9
thanks for all the suggestions and links. XD
and those recent ones are even more perfect for what I wanted! thanks.
Here are some new shorts.
