Where do double shoes parent too?
So I was thinking earlier...when a pair of shoe loads in for G2F, where do the ones that's a single item for both shoes parrent to?
I mean, left and right shoes would parent to the foot I assume, but the others?
  • If they are props they come in as single items they parent to the foot, if they are a pair or just a rigged single they are fitted to the wearer and usually parent to the figure node (but that is to enable the use of hierarchical poses, and to keep things organised, not to make them fit properly).
  • ValandarValandar Posts: 1,417
    Yeah, a "pair" of shoes usually simply conform, not parent.
  • almahiedraalmahiedra Posts: 1,365
    If for a  reason you need parent, you can parent a pair in the left foot and set no visible right nodes in the shoes, then load a new pair, parent to rigth foot and set no visible left nodes in the shoes.
