Plugin
NewName123NewName123 Posts: 6
Hi...... Is there a plugin to convert old numbers of Daz like an exemple like  Sku 07876 Stage fx Pro....... a folder .EXE
i install-it but c'ant find anywhere  Thank's for help.
  • Moved to Technical Help as it does not seem to be an AI topic - though I am not entirely certain what you are wanting. If you are having trouble finding fioles for products installed through DIM you can click the i icon to open the readme, which will give the location inside DS, or you can right-click on the product in the Installed tab of Install Manager and select Show Installed Files.
  • Is there a plugin to convert old files like . EXE to work with Install Manager I would very appreciate if somebody could answer me.
  • frank0314frank0314 Posts: 14,736
    edited February 2025
    exe's haven't been used for quite some time for content. What product is it? Is it from Daz? If from Daz there should be an updated DIM file unless it's a really old product and was culled from the store at some point.
    Post edited by frank0314 on
  • Threads merged.
