Removing d-former
So I added a d-former to a figure and after using it in my animation, any facial expressions I use on the figure are distorted. How do I removed the d-former? Can't seem to get rid of it from the figure.
Post edited by JImW on
Is it still a dFormer? If so just select its parts and delete them. If you spawned a morph and didn't save it as ana sset, just right-click on the Paramaters pane to put it in Edit mode, then right-click on the slider to remove it. If you did save it as a morph/modifier asset you will need to find the .dsf file and delete that (e.g. go to /data/daz 3d/Genesis 9/base/morphs/name you entered for publisher/name you entered for product/ and delete the .dsf file named for the morph).
